ORIGINAL: yamahate
Could you explain how more oil is going to make more power.
If you had a height rpm and hp mod engine, the best oil ratio is 10 ounces per one gallon gas fuel, some of the engine could reach 20000-21000rpm or even more on the speed test running, you will need the good enough oil to protect the whole thing that includes its power, rpm and the engine.
