RE: are these blades any good for cp pro?
Jeff,
I just tested out the "Y" connector on the batteries....very cool...they have about 24 volts when wired together...should have LOTS of power...LOL! So I'll effectively have a 6S battery pack...wow!! Only problem is that I only have THREE 2100 mAh Eflite packs...need one more to have two working batteries...
Hey, do you have any idea of how the EC3 connectors work? Or have you worked with them?
I can see that I need to solder the wire to the male terminals...but what holds the metal terminals in the actual plastic connector?
I think I saw something about that somewhere....?
Glenn
