RCU Forums - View Single Post - glow plug? prop? engine size?
Old 11-11-2008 | 09:13 PM
WingmanEPTX
Default RE: glow plug? prop? engine size?
hey stunt thank you! i had tried a 14x6 and a 12x6 on the saito fa80. i do understand that this plane isnt meant for speed, but the thing can barely climb a hill. if it wasnt for that huge wing it seems itd drop to the ground. cant even do a single loop without it fallin. i'd love to put a 91 on it...but the best i got is the ST61. hopefully that will do a lil better than the saito80. ill try those props you recommended on the 61 and see how it does! thank you much for your help!
*** on the EVO46 issue...got that sucker to idle beautifully now without dying or chokin up! thanks a ton minn!
*** i know i should know this by now but, now when i go from idle to wide open really fast it dies....if i go slow its ok tho. does this mean HS is too rich or too lean?...or more tuning needed on low end? =/ and weird thing is i seem to be turning the high speed valve 2-3 turns in both directions trying to peak but i cant hear a difference in the rpm! what the? does this mean its time for a new HS valve or needle or both? HELP!!!!!!
-is this hobby supposed to relax you or raise your blood pressure?!?! =)~
-KEVIN
