F15 JSDF If You read correctly, You could have read
www.flugmodellbau.de
The MB339 set itself is not mentioned on their site, it consists of a 3-light NAV light set (red, green, white), a nose mounted headlight, a beacon light on the top of the tail, a strobe light at the bottom of the fuselage, all powered from their Lighting Module Mini
http://www.flugmodellbau.de/product_...ight-mini.html
With this unit You can program the lights to glow steady or flashing, also the flash frequency type is selectable. Several functions can be controlled from your transmitter.
They come with suitable lens covers, even the tip mounted nav lights which have a tear drop form, come with suitable covers.
You only need a 4 cell normal battery for power.
Support is great by the owner, Mr Hajo Giegerich.
Cost for my set was approx 200 euros, w/o battery.
