When I was in my thirties, I used to hand start Quadra Q-35 engines with points. Never tried one without points. Even with points, it took a lot of energy and you had to accelerate the prop through ninety degrees before compression, or it wouldn't generate enough spark.
There is no way that I could hand start one today. I'm with the other fellow, use a spring starter or electric starter, unless you're young.
They are good and trusty engines.
