Bipe Fever???
Hi
i have also just flown my first bipe. 48" Panic. weighs 6lbs with a .91 2st. it fantastic, i cant stop recommending it, extremely stable when you want it to be. Any way your kinder right about bipe not gliding depends what you compare it to and what prop you use ie, low or high pitch and also how it balanced. I would say thou that it falls at a good rate when landing doesn't want to fall out of the sky but come down at a controlled rate. That how mine flies but obviously the skybolt could be totaly different.
There is such a thing as bipe fever as they look so good in the air.
Although its nice to have a change. so buy a different bipe then you can have a change when you want it.
