I picked the kit up about a year ago from another modeller. Not to sure how hard they are to get, but I always wanted one.
I am working on the cowl mount ring that will be glassed into the cowl. I cut the ring out using my scrowl saw, and I will use four metal pins that the cowl will slide onto, to ensure a good solid fit. I am done with attaching cowls with side screws. I will post as I go. Right now it is positioned into the cowl, and gooped into position with the cut out portion taped in to maintain its shape. I will glass it in after it is cured, and the mounting pins are complete.
Craig
