RE: RC Power -Duck Antenna
I used one of the early rubber duckie antenna for years without a problem.
The only issue is you need to be careful when you put the transmitter in the transmitter impound area. I recommend you remove the antenna when not using the transmitter. This prevents one from potentially leaving the transmitter on and the antenna being fully functional and potential shooting down someone.
I have never had range issues.
