RCU Forums - View Single Post - Prop Question
Old 11-24-2008 | 01:37 AM
Deadeye's Avatar
Deadeye
Default RE: Prop Question
Andrew, make a two sided 80 grit sandpaper disk. It should be about the same diameter as the hub of your prop. Use your glue of choich, but the rough sides should be facing apart. Make a hole as close to center of this disc as you can, and slide it on either after the spinner backplate, or before. The sandpaper grit will bite into both surfaces, thus locking everything into place.
