Old 06-03-2003, 06:11 AM
HarryC
Default Re: Re: IPD Receivers
[QUOTE]Originally posted by OhD
[B]
Originally posted by MPX_4000
IPD but I remember I was shocked by the loss of resolution as a result of the signal processing they do. It does get rid of the jitter but at a high cost in terms of resolution. If you are happy with it don't by good servos because it will be a waste.
That is not true. I use IPD with the JR8411 digital servo and the notion that the IPD receiver gives poor resolution is simply false. If you are getting a normal strength signal the IPD does not do any processing, that only occurs at the extremes of range or otherwise impaired signal where data is poor but not so poor that failsafe needs to kick in.
Harry
