RCU Forums - View Single Post - Problem with Ignition System
Old 11-25-2008 | 08:10 AM
thevirginian
Default RE: Problem with Ignition System
Is there a way to check if a hall sensor is bad? I am heving trouble lately with my ignition on my Brison 6.4. I get 5V to the Dean connector that connects the pulse switch to the module. If I ground the the Dean and interrupt it I get a spark, which tells me the module should be good. But how can I tell the sensor is good or bad?
