RCU Forums - View Single Post - Engine Mount ...Tap?
Old 11-25-2008 | 09:03 PM
JohnBuckner's Avatar
JohnBuckner
Default RE: Engine Mount ...Tap?
For engines up to 46/50 #4X5/8 sheet metal screws are perfectly fine, Use a 3/32 tap drill size no need to tap the beam and please do not use locktight which is redundant anyway.
If you use a #6X3/4 sheet metal screw which is used on sixtys the proper tap drill size 7/64.
John
