Old 05-31-2003, 02:49 PM
wgeffon
Default Futaba 9C Range Problems...
Wreck,
Make sure all you extensions are heavy duty wire.
I had exactly the same problem with my Cap initially.
If you are using any Y harness's make sure its plugged directly to the receiver and the the long extensions go out from there.
I dont think this applies to you because of single servo aileron set up.
I dont think its a range problem. My bet is that its in the set-up somewhere.
