Old 05-31-2003, 07:13 PM
WreckRman2
Banned
Default Futaba 9C Range Problems...
Originally posted by Giant Scale
Does the glitching occur with the engine running as well as off?
This is without the engine running...
I'm assuming you are running a gas engine?
yes but problems I am getting are without the engine running
Did you check for any metal to metal connections or other ignition related problems?
yes, tailwheel springs was only metal to metal and it was fixed
If the problems still persists did you check for possible rf noise from long extensions..etc?
the only servos that have long extensions (12" or more) is the elevator servos and with them unhooked the servos still jump around
Have you had this receiver mounted in any other planes?
yes for about 8 flights in a ucando with no noticable problems.
Did you try using another receiver?
yes, another 148df and get same results
Could your transmitter have been dropped or damaged?
never dropped, always kept in a case
Check to see if your transmitter antenna is connected properly.
did this also
