Old 05-31-2003, 07:21 PM
WreckRman2
Banned
Default Futaba 9C Range Problems...
Originally posted by wgeffon
Wreck,
Make sure all you extensions are heavy duty wire.
I had exactly the same problem with my Cap initially.
If you are using any Y harness's make sure its plugged directly to the receiver and the the long extensions go out from there.
I dont think this applies to you because of single servo aileron set up.
I dont think its a range problem. My bet is that its in the set-up somewhere.
Using Expert 22g extensions with the elevators being the longest however if I unhook them both I'm still getting intererence. No Y harnesses, every servo has it's own channel slot in the rx.
I've over looked everything in the plane, nothing is within 2" of the antenna.
I tried another module pack last night from a friend, swapped the crystals and still same problem. One could say it might be the crystals but I thought either they worked or they didn't.
I'm supposed to meet Tim later today and were going to put my module in his radio and see if we get a good range test. If we do then that points everything to the radio itself.
