hay all wfly radio systems what do you know about them any one. thinking of one for my low buck heli
http://www.flixxy.com/jet-man.htm << this guy gives new meaning to jetman and i posted this like 3years ago but could not find lol
The main functions are as follows:
Pitch Zero Trim (PZT).
Pitch Length Trim (PLT).
Be used for CCPM helicopter, airplane,car,boat.Standard 6 channel output.
Compatible with simulation softwares.
Channel 1,2,3,4,6 reverse switch
CCPM helicopter pitch reverse
CCPM state, aileron reverse switch
CCPM state, elevator reverse switch
Normal flying and 3D flying.The transmitter will alarms if it is turned on in a Idle-up state, and no output.
Dual rate
Throttle hold
Gyro Sensitivity adjust
Idle-up throttle adjust
Sound-and-light indicator for low power: When the battery Volatage is below 8.8V, the power indicator light 1S/1S glitters and buzzes.When it is below 8.3V, the power indicator light 0.5S/1S glitters and buzzes at the same time.
