RCU Forums - View Single Post - Balsa USA ENFORCER
Old 05-31-2003 | 08:45 PM
William Robison
Default Balsa USA ENFORCER
Q-Ball:
Want speed? That 61FS should pull a 12x8 fine.
I run a 12x6 three blade on K&B 61 engines without trouble.
The problem will be finding the props in a reversed pitch.
OS used to supply reversed rotation crankshafts, if you can find one you will have a much greater prop selection, as you will use conventional props ane crank the engine "Backwards."
Bill.
PS: Ralph - Beautiful. wr.
