ORIGINAL: martno1fan
Not all transoms are at 90% mine def isnt on my own stepped vee design so far its never been a problem setting one up but then i dont use stingers or outdrives on mine,even if i did a small offset can be made using some hardwood cut to shape
.The fountain hull is another example its transom is also not at 90%.
Mart
Mart,
you mention your own stepped vee design in the above posting, is it not the case that on the hull you make reference to, that you, in fact, copied it from someone you bought it off?
I know you made the freeboard higher etc, but, still a copy and I don't think you can claim it as your design.
Regards,
Glenn
