RCU Forums - View Single Post - Info on the OS #72 Carburetor
Thread
12-01-2008, 10:19 AM
4
rainedave
My Feedback: (
1
1 Post
RE: Info on the OS #72 Carburetor
Thanks Waco Driver! PM sent.
Well, mine has the #3 low speed mixture part.
However, there is a set screw in the barrel and the mixture sleeve can be rotated to fine tune the setting. I rotated the sleeve so that it almost seals off the spray bar when the throttle is set to low idle. I used the method of blowing through a piece of fuel tubing and adjusting the sleeve until air would barely pass through the spray bar with the barrel slightly open. I have not tested this carb on an engine yet.
David
Reply
Like
rainedave
View Public Profile
Send a private message to rainedave
Find More Posts by rainedave
View iTrader Profile
