Hi Ron,
Mine is this TJT3000 model, not sure if it's a V1 or V2 or??? i bought it off from an Australian jet flyer called Garry Turner two years ago, it is running well with a FADEC ecu i bought new from FADEC website.
http://www.xicoy.com/catalog/
But after reading this thread i'm very happy JETFX is carrying new parts and upgrades for this brand of engine, it's a good-running engine!
I am not sure of it's thrust values also, Marty, do you know what is the thrust for my turbine? I was told it pushes out 30lbs of thrust. I flew this engine with the Skymasterjet F-15 airframe a year ago, empty weight was 14.25kg and still flew well, i know this F-15's dry weight should be around 11kg but it seems to be putting out good amounts of thrust. I was flying an early version F-15 which is heavier.
I am currently painting a new Skymasterjet F18F Super Hornet and will be putting this engine into it. Should the thrust be enough Marty? or is there a thrust upgrade for my engine also? Frankly i only want to do scale flying. If mine puts out 30lbs i am happy already. I have adjusted the ecu to provide even better acceleration/deceleration and tested thoroughly on the bench and it performs very well now.
My F-15 flight video link below, that is my first taste of jet flying, foregive my kangaro landing at the end though, that was only the 2nd flight in the video! LOL!
http://rcuvideos.com/video/StevenWon...-2nd-flight-vi
Cheers!
Steven Wong from Sunny Singapore
