RCU Forums - View Single Post - Piston material
Old 12-04-2008 | 10:50 PM
Broken Wings's Avatar
Broken Wings
My Feedback: (20)
Default RE: Piston material
ORIGINAL: kersplat
Use 7075 T6 and you will not be dissappointed.
Try 380 or 390 series aluminum alloy. 17-19% silicon for 390..., 7.5-9.5% for standard 380 alloy material.
Hypereutectic 390 refers to a unique aluminum piston alloy that contains dissolved and free silicon. The material can be T6 heat treated to high strength and stiffness. Non-heat treated 390 hypereutectic alloy aluminum has slightly less strength than conventionally cast F-132 aluminum. You can machine it and use it...
Remember the K&B .65 Sportster engines that used no crank shaft bushings or cylinder liners...Smiles
