RE: Matchbox Problem
David, The way the matchbox works you plug your servos in and dial the selector to # 1 or 2 to set the throws and then if you need to reverse one of the servos you set the dial to to either 5 or 6. 5 for the #1 servo or 6 for the # 2 servo. flip the switch and then be sure to dial the selector back to 0 before unplugging the battery or switching off, this saves the settings. I'm quoting this from memory so if this a little off maybe someone will correct me. Bill
