Post Turkey Day work!!!
Hi guys!
Well, as it turns out I am having LOTS OF FUN learning all about Mechanical Retract and servo selection for this purpose. As you may all know by now, this is my very first RC Airplane Model with Pre-Installed Retracts and it has certainly been an educational experience!!! I am grateful as next time I will pay more close attention to this Servo Capacity specification known as TORQUE!!!!
The Bottom Line: I was forced to remove my Scale Rubber Lite Wheels that I had installed and went back to the STOCK Light Foam Wheels as the Retract Servo, Hitec HS-81MG just does not have enough TORQUE to lift the heavier Scale Rubber Wheels but, it does have enough TORQUE for the Super Light Foam STOCK wheels that came with the model.
I am back with some neat VIDEO showing you what happens when you select a servo that will just work with the STOCK super Light Foam Wheels. Nothing wrong with the selection but, if you all later on like to replace these STOCK wheels with something much heavier then, I learned that the Hitec HS-81MG really does not have that much TORQUE to do the job with the heavier Scale "Rubber" Wheels, even though the package says Lite Wheels!
Here's the VIDEO (PART #1):
http://www.vimeo.com/2367517
Here's the VIDEO (PART #2) <-SUCCESS!!!!!!!!!!
http://www.vimeo.com/2367530
