Old 06-02-2003, 12:48 PM
bentgear
Default Transmitter Cases !! Guys!!!look Here!!!!
The bad part about the one from Lowes and a couple other locations is you still have to go out and buy foam to go in the case. Every once and a while Harbor Freight and WalMart get in some aluminum cases that have the foam already in them. This is the foam that is precut into little blocks so all you do is pull out the blocks for a custom fit. Bought several from WalMart two years ago and they are still in use.
The ones with the dividers so make good tool and part boxes.
As far as the JR case being junk, I think what you were looking at was a junk case somebody placed a JR sticker on.
Ed M.
