RCU Forums - View Single Post - Evolution/MVVS 26gx
Old 12-11-2008 | 02:33 PM
pe reivers
Default RE: Evolution/MVVS 26gx
ORIGINAL: ggroyal1
I receieved my new Evolution/MVVS 26gx engine today. It did not come with breakin oil(my45gx2 came with break-in oil), can I use Amsoil 100:1 golden sabre at the 30:1 mix for break-in. Mobil 1 quit making 2T racing synthic oil. Does the slanted spark plug add anything to the performance? The engine is going into the H9 Sundowner and I plan to use the tuned pipe that goes with this engine. Is this engine different on break-in because of the piston and cylinder material? In the past I used Penziol air cooled 2 cycle at a 32:1 mix for the first 2 to 3 gallons and then switched to Amsoil 100:1 mix. This engine looks well made and if it is as good as my 45gx2 it will be a great engine.
George G. Royal
In the new design engine, you can use the pennzoil and stick with it at a ratio of 3% oil.
If you plan to use the 100:1 Amsoil, (not recommended) mix it at 2% (1:50) This oil has a mix range of 1% -2%. Any less than 2% oil, and these small engines will be starving for oil.
BTW,
Mobil 1 is still available. I have it in stock.
