One thing you might want to keep in mind - virtually every DL50 in my field (4 or 5 so far), had to have the bearings replaced after about a year. In some case, when the bearing parts floated elsewhere in the engine, the ring or cylinder, got damaged as well.
It's a strong and cheap engine, but definitely uses cheap bearings.
After the repairs, people found themselves suddenly at the cost of a DA-50, which seems to use better bearings as they do not fall apart...
ORIGINAL: houdinimkii
I see the DL is off to a good start, this is kinda' what I expected however the Area is getting some good feed back as well in the forum.
Keep it going!....Thanks guys and gals.
