Introducing the new 150cc Ultimate 20-300
Aeroworks is proud to add the New 150cc Ultimate 20-300 to their line of QUICK BUILD Series Aircraft
Designed by Jason Noll to provide the best performing Ultimate to date. The New Ultimate 20-300 has been designed to out perform any other Ultimate on the market. With minimal mixing and aileron differential required to achieve perfect flight, creates the truest flying Ultimate EVER! The 150cc Ultimate is a true QB offering High quality, light weight construction and fastest build time possible.
Aeroworks has Raised the Bar
The QB Series is top quality in both design and performance that has set the standard for the ARF aircraft market!
With the Ultimate’s unbeatable stability and precision flight characteristics it is certain to please both the beginner as well as the advanced competitor
Designed for both precision and 3D style flying this plane is sure to out perform all other aircraft.
The Ultimate was designed from the ground up to be a top performing aircraft. Generous control surfaces and an awesome power to weight ratio make this a plane you'll want to fly every visit to the field!
SPECIFICATIONS
Wing Span 94 inches.
Wing Area 3250 sq. in.
Fuse Length (Rudder to Front of Cowl) 107"
Fuse Length (Rudder to Front of Spinner) 113.5"
Cowl Width 15"
Weight 41 to 42 lbs
Engine 150cc
Radio 8 Channels minimum
FEATURING
Strong Light Weight Construction
Complete and Detailed Instruction Manual on CD
Carbon Landing Gear
Carbon Tail Wheel
Complete High Quality SAE Hardware Package Included
Adjustable pushrods with Centering Nut
Machined aluminum engine stand offs included
Carbon Reinforced Wing Spar Design Increases Wing Strength and Eliminates the Need for Flying Wires
No Flying Wires Required for Wings or Stabilizer Speeds Assembly at the field
Pre Installed Center Cabane
Carbon Wing and Stab Tubes
Professionally covered in ULTRACOTE™
Pre-Hinged from factory (Ready to Fly)No gluing
One Servo Wing
One Servo Elevator
Large control surfaces double beveled for maximum throw
Pre Mounted Fiberglass Cowl and Wheel Pants
Flush Fit Cowling with No External Mounting Bolts
Pre Mounted and Tinted Canopy
Pre installed and fuel proofed engine box
Laser cut engine mounting templates provided
Custom Throw MeterIncluded
Extra Ultracote™ covering provided for small repairs
Two Fuel tanks One for Smoke
12 to 14 Hours assembly Time
Expected Delivery Late Feburary 2009
Pre-Order Today!
More pictures [link=http://aero-works.net/store/detail.aspx?ID=351]here[/link], look for the video and manual coming soon!
