RCU Forums - View Single Post - WFLY RADIO SYSTEM any1 ever use this brand
Old 12-19-2008, 08:27 PM
dude7422
Default RE: WFLY RADIO SYSTEM any1 ever use this brand
The 6-channel DX6i uses the same full-range DSM2™ technology found in the Spektrum DX7 and includes an impressive list of programming features for both airplanes and helicopters that are simple to access and use. It comes with the new AR6200 DSM2 6-channel receiver that is robust enough to use in large models yet compact enough fit in many park flyers. The DX6i is also compatible with all existing Spektrum aircraft receivers. Whatever kind of flying you do, the DX6i can be adapted to most any model in your existing collection that requires 6-channels or less.
Key Features
Full range 2.4GHz DSM2 6-channel radio
10-model memory
ModelMatch
ServoSync
Roller/selector user interface
Attractive and ergonomic design
Proven DSM2 technology
Rudder dual-rate
Large LCD display
Integrated timer
Contrast Adjustment
Dual-speed trim scroll
Model name and type
Throttle cut
Trainer Mode
Model Copy
Travel adjustment
Sub-trim
Servo monitor
Dual rate and exponential
Compatible with any existing DSM and DSM2 receivers
Airplane Programing Features: Flaps, P-mixes, Dual aileron, V-tail, Delta, Differential
Heli Programming Features: Gyro adjust, Graphic throttle curve, Graphic pitch curve, P-mixes, Revo mix, Swash type (Normal, and CCPM 120)
Adjustable stick length
Direct trim access display
Included.
DX6i system
AR6200 DSM2 reciever
4 x AA batteries
Bind plug
price 179.99 is that a good price????? this is a copy paste radio from hobbycity
