RE: Charging Li Ion supplied with Rhino
Guys I use LIONS in my Giant Scale planes and was thrilled to see this in the RABBIT.
Chargine is simple.
Like Eric said.......any LION or LIPO charger will charge it. LION do not need to be balanced while LIPO does.
Your best bet is to charge at 1C or less. With the battery being a 7.4v battery I would charge in this range 1.2-2.4 amps. Or set the Mah and charge that way. It depends on what charger you own on how it will charge. I have the Triton and the Fromeco ION cube and both of those typically ask for an amp setting.
