Old 06-02-2003, 11:29 PM
Stormbud
Default Best way to reverse a servo
Thanks Mike
I am thinking pretty much like you. The plans call for both linkages to be on the same side(closer to the stab) , I assume this is to keep them as close as possible to the same geometry.
As far as buying the eight channel, I am using 1 and 6 for ail. and the manual calls for useing 2 and 8 for dual elevator servos. But now that you mention that, I am sure if I sat down with the manual I could make my own mix and use 2 and 7(or 5). The futaba 8UA (sorry cant remember the rest and am too lazy to run to garage!) has many mixes you can set up on your own. Anyone done this?? Thanks again Mike!!
