RE: CAMODEL PASS-PORT BUILD (very slow)
More work done.
finished the rudder post, sanded double beveled for extra rudder throw.
then installed hinges
instal the rudder in place and hold it tight with some masking tape so I can sand the rudder tips to shape using the fuselage as a guide.
marked rudder control horn location and rudder pull-pull cable exit holes in fuse using a long thread holding it from where the rudder servo should go.
installed rudder horn
installed tail wheel.
pictures...
