RCU Forums - View Single Post - BVM FJ-2 Fury Build
Old 12-26-2008 | 09:34 AM
k_sonn's Avatar
k_sonn
My Feedback: (32)
Default RE: BVM FJ-2 Fury Build
After the hysol flex plate seats were dry the nose section formers were hysoled in place. Once the hysol was set, the nose gear doors were installed. The front door has a cut line in it because the front door on the F-86 is in two sections and is hinged so that when the gear is extended the door folds into an angle. The front door on the Fury is one piece so I sanded out the cut line. The doors are a little fiddley but with a little patience they align and install nicely. The spring to pull the front door shut when the gear retracts has not been installed yet,
More to come later .....
Kirk
Not a BVM rep, just a very satisfied customer
ID:	1096807   Click image for larger version
ID:	1096808   Click image for larger version
ID:	1096809   Click image for larger version
ID:	1096810   Click image for larger version
ID:	1096811   Click image for larger version
ID:	1096812   Click image for larger version
ID:	1096813   Click image for larger version
