RE: help with brushless electronics.
Is it re arming when it starts back up ? If so then its a loose joint somewhere on the battery side of the ESC or it could be the on/off switch is bad .
What is the LVC set at ? I wouldnt charge the batts in series either , just charge each one individually .
