Do volcano's have weak shocks???
Just came from outside driving the volcano a bit. It kept pulling to the left so i stopped it to check it. When looking at it, i could see that 1 of the shocks on the left front side was bent. The fork in the center was bent and wouldnt let the shock move. Is there any better shocks to put on it or is stock about it? I have the s30. I dont think it has any aluminum parts. Also, it seems as thought the the throttle sticks when you first use it and let off. It wants to keep going unless i hit the brake, then it idles down again and stays there till i hit the gas again. I checked the idle screw and have it set right. I played with it and adjusted it till it wouldnt die when i hit the brakes. Is there something else that could cause this?
