Balancing my Stingray
Ok here's a couples of (dumb?) questions :
1- They said 5.75" from the root of the wing. Is it realy from the wing's root or i have to take the part that is molded in the fuse?? It should be from the wing 'cause from the fuse root it's amost impossible to balance.
2- Did you balance with upper tank full?? I guess yes, 'cause it should always stay full...
3- I didnt fly tri-cylce since 10years so do i have to put the main a little bit outside or inside??
Thx,
Claude Perron
