1/4 pacific laser 200 engine recommendations
I purchased the kit a souple of weeks ago, and I am in slowly in the process of building it. I just read the reveiw in RCM and PAM has made a few changes in the kit from the kit being reveiwed.
1. Elevator control has been changed to dual servos in the tail. Cutouts are already in place and they are even setup so that you don't need a reversing Y harness to make them travel in the same direction.
2. In the earlier kits, the builder had the option of gluing the wing together or keeping the halves unglued for ease of transportation. Now, the wings are the plug-in type with an aluminum rod and nylon bolts that pull the halves into the fuse. There is no option for gluing the halves together.
3. The canopy hatch is now smaller than the original version, I think due to the fact that they changed the wing mounting system.
I am running a Saito 120 4s with a 15x8 Zinger prop. Hitec 645mg on each elevator half, Hitec 605 on the pull-pull rudder, JR 537s on the ailerons and throttle. Also Hitec 1100mah battery. JR 662 radio system.
I hope to have the model flying within the next week!!!
Seth
