RE: PiccoZ Micro R/C heli
Uh-oh. The heli won't charge and I can't find why. The wall charger works fine but the heli won't accept a charge. The tx charger light comes on when I plug it in but only for a blink. Help? Also, the wall charger has an LED that turns OFF when charging starts and ON when it ends or nothing is plugged into it. I plug it into the heli and the light turns off. Well, the heli batt is like 50mAh and this thing has a charge rate of like 500ma. I can do math and I'm pretty sure it doesn't take 1/2 an hour to fill that batt. Light go off but light don't wanna turn on[&:] Wiggling the plug in the charge socket makes the light flash on and off so it seems like a loose/broken connection.
I'm especially worried because I already burned the box.
Any help would be greatly appreciated, as I don't have $25.09 for another one at the moment. Also, if it's a batt problem, I have lots of extra lipo cells laying around, ranging from 40 to 380mAh so it's not a problem.
