RE: glassing the wing center section
Save the weight by doing the normal fiberglassing with finishing resin, then use waxed paper on top of the resin. Smooth it out with a plastic card or try the vacuum bagging. After the resin has cured, the waxed paper peels off, leaving a smooth surface. A little light sanding, and you're off to the races.
Brad
