RCU Forums - View Single Post - Tips for using Balsarite
Old 01-09-2009 | 01:27 AM
jrcaster's Avatar
jrcaster
Default RE: Tips for using Balsarite
Covering sticks better to Balsarite than to Balsa alone, and lots better than to plywood alone.
Use a low temp quick tack with your sealing iron, (barely touch the covering and get off) or you will pull the coloring off if you need to move the covering.
