RCU Forums - View Single Post - Overlander/Cermark Extra 260
Old 01-09-2009 | 06:41 PM
louisben36
Default RE: Overlander/Cermark Extra 260
Hi,
I`ve just got the Overlander Extra 260 too. I got it from "Model shop Leeds" for £44.00....what a bargain!!!
It`s only had a handful of flights...thanks to the big CHILL, can`t wait for summer
What was your flying weight?.....mine is definately heavier than the manufacturers stated flying weight. The only modifications i made were larger 2" lightweight foam wheels and a DU-BRO pull-pull system, as i thought the stock one was poor and difficult to setup.
Is there a great difference in performance with the wood prop as opposed to the APC?
My setup is:
TORNADO THUMPER 3548
E-PRO SP50A-BEC-AIR BRUSHLESS ESC
HITEC HS65 HB X 3
HITEC HS81 X 1
APC 14 X 7 E
FLIGHTPOWER 3S1P 3700MAH LI-PO
FUTABA R617FS 2.4GHz FASST RECEIVER
LOUISBEN
