RCU Forums - View Single Post - BVM FJ-2 Fury Build
Old 01-09-2009 | 07:02 PM
Ron Stahl
My Feedback: (12)
Default RE: BVM FJ-2 Fury Build
The parts look great as usuall from BVM and the inscruction book is a great source of data as well as your pictures. I have removed the turbine tank mount and pump mounts. NowI have to dremel out the rear nose gear mount that is plywood to replace it with the end grain
balsa/ carbon one. It looks like I will cut down the main wing mount wood pieces to match the ones supplied in the conversion package since they are in and aeropoxied in place. The servo mounts for the elevator look like the ones from the kit so I will double check that they donot have to move. The biggest job looks like the gear doors. Hopefully I can get back on it next week once all of the Xmas stuff is put away this weekend.
