RE: prop driver removel rcv 120sp
the prop backing plate is what I need to remove. it is on a tapered collet which fits on the prop shaft. I need to pull the prop backing and the collet off the prop shaft so I can get at the bearing and remove it. since it is a tapered collet, It is a press like fit. I need to use some sort of puller to get behind the prop hub and pull it straight off. I guess my question is what can I use as a puller without bending the fins on the prop backing. I hope that's a little more descriptive. thanks
