Quote. I will get a coffee and begin reading again thank you. You may tell me to read again on this one, but what is the easiest way to bend the copper tubing for the flex shaft? I can't find my tube bender.
Here you go!
Find a close coil spring, like the springs used in campervan curtains.
You don't want a thin wired spring, get one that has thick wire and tight windings. (it helps to put some heatshrink tube over the spring, for easy removal later).
You need one thats a snug fit, but not tight.
Insert the spring into the tube and bend it by hand around something round, like a "beer bottle"
or something simillar.
After you have the right bend, remove the spring.
Hope this helps, Brett.
