RE: Handley Page Halifax 1/9th scale
Thanks Walt.
Well I am trying to move along quickly as I can. I feel time catching up with me on getting this done..Well I have put off finishing the bottom of the fuse under the wing.
When I had origianlly framed up the fuse and sheeted it, I had marked off the wing location and also added extra formers to the front and back of the wing saddle area.This would allow me to cut away, as a unit the fuse under the wing. I looked back through the thread and i never showed cutting out the wing saddle area.
I had set this aside until now. Anyway I mounted the wing onto the fuse. I trimmed the section that I cut away until it matched the fuse at the leading edge and trailing edge. I then added four tabs so I could use screws to hold this on as a unit to the bottom of the wing. I will make this my removeable bomb bay later. Once I tapped this for 14/20 screws I finished sheeting it....
Ty
