RE: Ernst Charge Receptacle...?
> maybe a bad run/batch was made some time ago....<
The plugs are a very tight fit going into the jack receptacle. But there have been some bad jacks that were impossibly tight. Contact the maker and see if they will help you. And look carefully inside to see which side the tiny lip that guides the connector is located.
