Old 02-06-2009, 04:24 PM
bruce88123
Default RE: hi-band vs. low band which is better
No real difference between the bands as far as quality. It's just a tuning thing. If you cross the bands low crystal in a high RX or vice verse the RX will be slightly less sensitive.
If you buy http://www3.towerhobbies.com/cgi-bin...&I=LXLSX4&P=SM it is NOT high/low sensitive and can use ANY correct Futaba 72MHz crystal. Ch 11 and above.
Aftermarket RX's are also not sensitive to this condition nor are other major brands.
