RE: HET Sniper 70mm EDF build
Hi everyone i have the sniper too and it´s a really fast mini jet and very fast as well. i haved to make a little mod to the landing system i add some wheels to it for take off and landing on the runway.
the setup that i´m using is:
- wemotec 480 70mm fan with 5 blade impeller
- Lehner 1530 motor
- 5S 4500mAh Align batterie. (split in two parts 4 cells all around the fan unit al the otherone in the front. this batterie setup is for balance)
- elevator servo it´s a HS-81MG
- aileron servos HS-125MG
- steering wheel servo HS-55
here are some pics
