ORIGINAL: Dorian AM
Likai
I do not understand useful the GYA352 to control roll and pitch fore the vector thrust?
My GYA352 control Roll and yaw.
Fore control roll and pitch, I have to fix like that
Could you help mi?
Hello Dorian:
Using GYA-352 for pitch and roll, you have to put "ALV switch" to "ON" position. When ALV is turned on, the gyro will convert roll (x-axis) and pitch (y-axis) signals from Rx to delta-wing type signals for both up/down servos of nozzles. This is meaning that you don't need to set delta-wing mixing mode in your Tx for nozzles control and just leave it in normal-wing mode.
Do you have the instruction manual of GYA-352? If not, please give me your e-mail address and I can send PDF file of it to you.
Best regards
