RE: epoxy dangers
Glued my bum to the chair one night. When i got up it ripped a hole in my pants. The biggest danger was my wife ! If you use it everyday you should wear a resperator, It can cause some short term breathing problems, And the combination of chemicals can destroy the oils in your skin causing irratation. But breathing it is by far the most dangerous effect from epoxy. When in doubt use PPE.
