RCU Forums - View Single Post - HELP on Morris The Knife control problem
Old 06-09-2003 | 10:56 AM
stomper
My Feedback: (20)
Default HELP on Morris The Knife control problem
Hey Dick
Take a look at the plans. they show where to install the pull-pull cables. when done you want one rudder cable to exit out the rear on the right side of fuse., and the other to exit out the left side. For the elevator, you want both to exit rear of fuse. on left side ( one below elevator and one above). Up front you want both rudder cables to exit the right side of fuse just forward of the trialing edge of the wing, and the elevator cables to exit on the left side of fuse in front.
Looking at the wing up side down, you will have three servos in the left side, and two servos in the Right side.
The left side servos are> outside for(Right ) Aileron and inside for elevator.
The right side servos are> outside for (Left) Aileron, Middle for Rudder, and inside for Throttle.
Not sure this will help, but I hope so.
Will try and post a picture or two later.
Doug
